tellanand
After a long time of research and waiting, I've finally bought a Onkyo TX-SR608 from the US. I've to now buy the step down transformer, speakers, cable etc before I can set it up. My hands are itching to set it up. I'm from Chennai.
Can experts / owners of Onkyo around here help me with buying advice on the following - please?
[1] Step down transformer. The rated power of 608 works to about 680W, I think. Should I be buying a 1KVA or 1.5KVA for this? Is Maxine a good brand to go with? Where can I buy Maxine transformer in Chennai and what's the approx cost (of 1kva or 1.5kva)?
[2] What's the recommended speakers for 608? My budget is about Rs.1L (can stretch it to about Rs. 1.3L. My room dissensions are 12' x 12'. I prefer to have speakers that are not bright (like Klipsch).
[3] Are Bose speakers a good option to consider at all?
[4] What speaker cables would you recommend. I'm confused by the range of speaker cables that's available.
[5] Can you also recommend the list of speaker showrooms in Chennai that I can visit for auditioning and selection?
Thank you so much for your help.
best regards
- Anand
Edit: I'm not sure if I posted this in the right forum. Mods, please move it to the Speaker section, if this post is not relevant in this forum. Sorry for the bother.
best regards
- Anand
