are you sure about the price? I got it for about 40 $ from ebay US a few months back..no custom duty.
ganesh
I thought of buying this but opted for a carbon fiber brush instead. Most of my records just have a few dust particles that float down when the disc is spinning.
Anything that needs more cleaning than this doesn't make into my LP collection. I buy a cd or flac instead.
I'm however interested in knowing the difference in sound quality with this. If possible, please do post a couple of 'before and after cleaning' photos with this and also before and after sound recordings if you can.
you will be surprised to hear the difference, when you clean a record that is freshly opened from a sealed sleeve.... One must clean their records every now and then. and the carbon fibre brushes are pure nonsense. i prefer the regular 3M microfibre cloth. its inexpensive and does the job better. my own audioquest cf brush is just sitting around these days!
Ah, I see. Any reliable local sources anyone knows of?
Hi Shivam
The Spin Clean system works. I have had it when i was into vinyl. Definitely recommended. Preferred it to normal cleaning with distilled water.
