Stereo amp for diamond 9.5
siddharthkrish
I've got a pair for 9.5's that I'm quite fond of, I've been using a denon 16xx for sometime with it now and am looking to get a proper stereo amp for it. Any suggestions?
I'm thinking NAD/CA/Arcam but am open to other options (including tubes if there are any decently priced ones).
Thanks,
Sid
Hi Sid,
You have not mentioned your budget.If it is around or below 10k you can go for the Norge amps.Wharf and Norge have got some excellent reviews on the forum.Or if your budget is around 25k you can look at a Marantz amp like PM 7001 or 7003.I myself can vouch for the Wharf and Marantz combo.They are made for each other.You can even look for an used Marantz amp with a decent power.Hope this helps.
cheers,
sri
I had the Wharfedale 9.5 paired with Marantz PM 7001 (@ 70 wpc) and in my opinion they matched well. The sound quality was excellent, though overall presentation was a tad on the warm / laidback side.
Cheers, Shriram
