Stereo receiver + BS speakers set
Arab
Blr
I am planning on a HiFi for my bedroom where Video is banned :sad:
My requirement
1) Play from USB or 3.5mm jack + component or coax
2) 2ch 50w is suffcient
3) FM is must
4) BS
5) Max 30/35K (inclusive of speakers)
I can see CA Topaz SR as the only option in India which is a stereo receiver + CA S30.
Are there any other stereo receivers available in India.
Is this the right approach or am I better off with a stereo only integrated amp + separate media player with FM + BS
I am open to used, if anyone has a set to dispose off, pm me.
My requirement
3) FM is must
4) BS
You can also take a look @ Onkyo TX 8020... But it doesn't have USB (TX 8050 has)... For bedroom this should be an ideal fit....Not sure abt indian price...
If you have sources in Dubai/ Malaysia get the onkyo TX 8050 / 8020 from there.... You will save lot of money....
For speakers, you can look @ Sonodyne Sonus 1501, PSB Alpha, Polk TSx & Cambridge S 30.... All within 10 - 15K.....
My requirement
3) FM is must
4) BS
If you can spend 32K on stereo amp alone then I guess Marantz M-CR603 Network CD Receiver is you best bet, it is a Network player, built in CDP, built in 60+60 W amp, built in AM-FM, can connect to internet radio stations too
Please check the For Sale section for used items and also you may post a thread in Wanted section.
Otherwise in less than 15K you will get Sonodyne SIA320 or Norge 2060 or 1000 which are very good.
