Subwoofer Project - Suggestions needed
elango87
Mysore
Dear experts,
Last year, i build couple of book shelf speakers and I feel that they sound okay as it was my first time DIY.
Later, With a plan of building a subwoofer, i purchased JBL CS1215 (Car sub) and then a 300 Watts plate amplifier from Parts-express shipped through ishopinternational.
Below is the link,
Code:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-750
After reading through a number of articles, i feel that trying to use a car sub at home is not going to work.
Now, i have decided to sell the sub and buy something new. I couldn't find any subs which could be powered by the plate amp i purchased.
Can anyone suggest some good subs which are available in India under 10K?
My usage would be 80% music and 20% movies.
Below are the specs of JBL CS1215 if required,
Code:
Diameter: 12" (305 MM)
Sensitivity (2.83V@1M): 90dB
Power handling: 275W RMS 1100W PEAK
Freq response: 23 Hz - 450 Hz
Nominal Impedence: 4 ohms
Voice-Coil diameter: 2" (51 mm)
Outer diameter: 12-1/4"(311 mm)
Mounting depth: 6-1/16"(153 mm)
Cutout diameter: 11"(279 mm)
Thiele-Small Parameters:
Voice - coil DC resistence: R evc (OHMS) - 3.6
Voice - coil inductance @ 1kHz: L evc (mH) - 2.57
Driver Radiating Area: S D (IN^2) - 85.4
Driver Radiating Area: S D (M^2) - 551.00
Motor Force Factor: BL (TM) - 14.08
Compliance Volume: V AS (FT^3) - 2.7
Compliance Volume: V AS (LITERS) - 76.7
Suspension Compliance: C MS (microM/N) - 177.00
Moving Mass, Air load: M MS (GRAMS) - 179.00
Moving Mass, Diaphragm: M MD (GRAMS) - 171.00
Free-AIR Resonance: Fs (HZ) - 28.00
Mechanical Q: Q ms - 8.85
Electrical Q: Q es - 0.57
Total Q: Q ts - 0.54
Magnetic - GAP height: H ag (IN) - 0.307
Magnetic - GAP height: H ag (MM) - 7.8
Voice - Coil Height: H vc (IN) - 1.26
Voice - Coil Height: H vc (MM) - 32
Maximum Excursion: X MAX (IN) - 0.48
Maximum Excursion: X MAX (MM) - 12.1
Thanks,
Elango
Dear experts,
Below is the link,
Code:
Code:
Thanks,
Elango
well the driver favours a sealed box. Approx 60litre ID will give you an f3 of 40hz (which being sealed you can equalise)- so with room gain you could be flat to 20hz.
Ported is larger -- 80 litres ID tuned to 24hz. should give you a f3 of about 25hz. this is a more HT favoring alignment and it will go loud..
this is back of the envelope, but i recommend sealed. ported will not be "tight"
if you want to buy another driver, do you have a budget in mind?
Thanks for the reply. I dont want to use JBL.
I can spend around 10k for the driver.
a diy favourite at low cost is another car audio woofer - infinity 1260w.
home audio - i guess you can import; cannot comment on any of the locally available brands except seas, which would be out of your budget.
Dear experts,
Below is the link,
Code:
Code:
Thanks,
Elango
If you are a serious DIY and adventurous enough, please see Elektor electronics March, April, May 1996 issues. there is a great article about sub. If you dont have , PM me showing your mail ID. I shall send you.
Do you know what is the approximate price of this driver? In the stores online, i could see them listed between 3500 till 7000 :confused:
Looks like i cant PM you. PM option is disabled. Can you send me a PM? I will reply back with my id.
Thanks,
Elango
