Hi Satish/Audiodelic
I followed the Set up steps to convert my OPPO 980H to all zone as suggested by you.
I was successful in this. Now I just have to try few movies of asian region.Basically I am using 980 as Transport to feed my Monarchy tube DAC.
Thanks a lot.
I have another 983h which I bought locally for watching DVD's.
But as my Philips LCD TV is older one with 1.1 HDMI input I am having problem using 983 HDMI output which is 1.3 and not 100% compatible.
It works some times but at times i have problem in sound and sometimes in vedio or both. The Vedio quality of 983 HDMI is to good to be missed.
So I can only use normal vedio output or Component.
Is there any solution for this ?
SKR
Great to hear the region hack worked with your DV-980H. Oppo's company policies are great i respect that company.
Concerning your 983h:-
I dont think the audio-video dropout issues are because of the hdmi 1.3 port, since hdmi is backward compatible.
I think i have the solution for you:-
Make sure you have constant power(electricity) while doing this. power cut out during a upgrade cold prove fatal for your player.
Do a Firmware upgrade (steps):-
1. Download the firmware from
http://www.oppodigital.com/dv983h/download/DV983H-06-0430/DV983H-06-0430.iso
2. Burn a CD from the downloaded ISO image file. Be sure to burn the CD as an ISO image file, not a data file. The CD should contain a 983.BIN file if you burned it successfully. Please consult your CD burning software's help/instruction manual for more information on how to do this. Some general instruction for common CD burning software is listed below.
3. Turn on your TV display and the OPPO player. Open the player tray and insert the firmware CD, and then close the tray.
4. As soon as the CD is loaded, you will see "Press Play To Start" on your TV display. Press the PLAY key on the remote or the player once. The TV display shows "File Copying" and then "UPGRADING"
5. In about 8 seconds, the CD will be ejected. Remove the CD quickly; DO NOT DO ANYTHING ELSE. What follows is the process when the player will reboot itself.
6. DO NOT PRESS ANY BUTTONS NOR ATTEMPT TO CLOSE THE TRAY NOR UNPLUG THE POWER DURING THE REMAINING UPGRADE PROCESS.
7. After approximately 1 - 2 minutes, the player reboots itself and closes the tray automatically to complete the process. The update process is completed when the front panel of the DVD player shows "No Disc".
8. Press the "OSD" button on the remote control to verify the new firmware version.
9. The new firmware may affect your HDMI output resolution and setup menu settings. To ensure you have the correct settings, turn off and then turn on the player. Press the HDMI button on the remote control to set the desired output resolution. Adjust the setup menu settings if necessary.
10. Congratulations! You have just completed the firmware upgrade.
Try this and let me know if it helped in fixing the dropout problems.
Where did you buy your Oppo 983H in India from ?
