surinder1508
I wanna connect my onkyo 807 to Polk's TSI 500/200/CS20 total length of the cable may be 35 meters so which one to buy minimum and second hand option is also welcome.
So called costlier hi-end speaker cables are one of the biggest scam perpetuated by the big companies. Unless someone can prove laws of physics to be wrong, ordinary 14-16 AWG speaker wire, which costs 1/10th of the costlier hi-end cables will work just fine. There are numerous threads in avsforums, even in the Ultra Hi-End HT gear section (upward of $20000), where members swear by regular speaker wire and have done numerous blind comparison tests and not found any difference in performance.
Seem there is huge debate on this. With my new Oknyo TX-NR5007 system due to arrive in a couple of days, I am gonna try out normal copper cables of 16-18 gauge (which I have as leftover stock) and see if the so-called costlier audiophile wires do indeed make a difference. While the quality of copper used may increase/decrease the resistance, not sure the cost justifies the improvement in sound quality.
Must read:
Speaker Wire
Can experts here clarify if normal electrical wires (finolex types) can be used for speaker wiring? The above link suggests so. Alternately, if I use the costlier cable for electrical wiring, is it supposed to lower my electricity bill and glow my bulbs brighter???
MX has new cable series which can be VFM.Other from Banbridge is good too.
Even DAC has good cables.
Must read:
Speaker Wire
First of all congratulations on your purchase of this monster BTW how much did you pay for it and what is your opinion after your experiment with cables.
What are price per meter from these brands and can I use normal 16 or 14 gauge cable made with good quality copper used?
Longest distance is 26' (8 meters apx) between speaker and AVR.
