Taga Platinum Floorstander regular vs Slim version
mahender
Hyderabad
I am unable to decide between platinum slim version floor standers vs regular floor standers if anybody got chance to audion both, could you please tell the sound quality difference between slim & regular.
There would be a difference in built quality and components used. Suggest you post this in the Taga Owners thread where you will get immediate responses.
If you prefer more compact FS, then choose slim version..
I own the slim version (LCR 60 SL) not the FS.. Drivers seem to the same between regular platinum series FS vs Slim series..Only the enclosure size seems to be different, if that will not have any effect on the sound quality, then they should sound the same..
Which two models are you comparing?..
