pawan_pullarwar
https://www.motor1.com/news/767467/bugatti-tourbillon-sound-system-no-speakers/
Rather than using traditional speakers, the Tourbillon uses piezoelectric elements that vibrate the car's carbon-fiber tub. So effectively, the Tourbillon's chassis is one big speaker.
Traditional speakers use a magnet that receives an electrical signal, which in turn moves an electromagnetic voice coil back and forth. The voice coil is attached to some sort of diaphragm, typically a cone made from paper or metal, that vibrates, amplifying the sound. (Remember that sound is just air vibrating.) Obviously, this works incredibly well, but speaker magnets are quite heavy.
A piezoelectric speaker uses a small crystal like quartz to do much the same thing. An electrical signal sent to the crystal vibrates some sort of diaphragm, usually a small piece of flat metal. Some hi-fi speakers use this technology, but more often, a piezoelectric speaker is just a small buzzer, like an alarm in an old quartz wristwatch.
In the Tourbillon, the actual carbon-fiber chassis is the diaphragm—those piezo transducers are designed to transmit vibrations directly into the tub. Rimac shows Top Gear the Tourbillon's effective subwoofer, a piezo element attached to the roof of the car. It's a tiny metal piece, far smaller and lighter than a traditional speaker.
"Believe me, the sound quality of that car is in a different universe compared to a Chiron," Rimac says. "So we saved weight, space, and improved the sound quality."
While this seems to be the first example of an automaker using piezoelectric transducers to turn a carbon-fiber tub into a speaker, the Tourbillon is not the first car to use part of its body structure for audio reproduction. Mercedes-Benz introduced a system called Front Bass that turned the front firewall of the 2013 SL into, effectively, a large speaker box. Though, this system did use traditional electromagnetic speakers. The car's structure was just used to enhance the sound from the speakers.
