Blue Floyd
I have ordered a denon 1911 from global ebay for Rs.32772 :clapping:
Hopefully should reach me in 15 -20 day
hyeah:
Couple of questions to fellow members:
1) Which would be the best under 4k step down/up converter with built in stab to buy ? (I have read lots of discussions on the various threads but am confused)
AVR is rated at 460W power consumption @110V
2) Which would be good sub 40k tower speakers with RMS handling of upto 150 RMS. (Will add and amp later to boost power later)
I prefer a crisp treble and a hard tight bass. 50%music 50% movies/tv.
Was earlier planning a 5.1 speaker system hence had shortlisted the Def tech pro cinema 600 5.1 system but on listening to it compared to a paradigm 90ct it didnt sound crisp/bright enough, The paradigm seemed better...
Though, after reading on the forum have decided to first buy towers and then add 5.1 system later.
AVR output is 90W@8Ohms and 125W@6Ohms per channel
Request your suggestions for the above two and also if possible where in Pune can I listen and get a good deal. Have tried Sound Factor and AV Excellence but both do not have any towers in the price bracket
Thanks!
Thanks!
