Tube Amp Parts:
hydrovac
Hyderabad
Hi all,
I have decided to junk my Cayin MT-12 A tube amp, and use the chassis for a pre-amp or small power amp build.
The tear down may yield in some interesting parts. If anyone interested, i can salvage them and send over to you.
Will list the parts once i disassemble the set... BTW, a remote control and tubes also available.
This was my bedroom setup:
Definitely interested :)
I could use the OPTs and tubes and pretty much anything else you don't want from it
I will be interested in the power transformers and power caps. Please let me know.
Thanks for your interest... one FM from has responded via PM for OPT and Tubes.
You can pick other parts.
Left with a nice mini chassis after stripping the amp.
I would be intrested in remote control, the sensor board for it And the input selection board.
Bharat Singh
nice gesture, and even though I have not requested any parts, thanks for the gesture, true to the spirit of our forum
wish you all the very best for the new project
Thanks for your kind words Reuben.
Please let me know if the other FM backs out. Thanks anyway!! :)
Sure, will let you know.
Bharat Singh
will courier these parts... Pl share your address.
A local FM picked up the OPTs, Tubes and Ceramic tube sockets...
Bharat Singh
@bhrtsingh
is neither responding in the thread nor to PM... any one else interested in the above?
Recently got these 200WPC mono power amp modules, i was already having suitable 42-0-42 @6amps power transformers.
Planning to use the Cayin chassis for the build.
The build:
Existing holes of transformer matching perfectly.
Had to cut open a slot for the module... the caps were a tad big and obtrusive, so changed to smaller... the caps are in parallel:
Hook up was a simple job and done testing:
This is how it looks with the cage on... a pseudo tube amp look alike:
One block complete... cool finished look:
Second amp also done:
have to make a dummy plate to cover the square transformer holes.
BTW, i junked the Cayin CD player also along withe the tube amps and used the enclosure and toroidal transformer to build a Baxandall tone control / preamp... very nice sounding with loads of gain.
