UPS for LG42lm6700
[email protected]
Madurai
hello,
i recently bought lg42lm6700.we have only 10 hrs power for a day.we have APC inverter(600va).i want to know whether do i need a stabilizer and should i connect my TV plugpoint directly to UPS slot?or the stabilizer be connected to UPS?my tv watts is 170 watts.should i upgrade it to 850va?since its a high end tv it should not get damaged.thanks in advance.please do answer all these.
The 600VA APC inverter is sufficient to handle the 170W TV. No need to upgrade to 850VA. Upgradation is needed only if you are connecting other power hungry devices also to the inverter. Stabilizer should not be connected to ups out. It can be connected before the UPS, but the VA rating of stabilizer should be higher like 1KV or 2KV. If there is not much voltage problems then the ups is enough.
