sumitkumar0102
Dear Gurus,
Can you please help me with the system settings for my Maruti Suzuki Wagor R (Small Size Car)
I have the following -
--> HU - Pioneer DEH-P6950IB
--> Rare Speakers - JBL Multielement CS 3196
--> Rare Sub Woofer - JBL GT4-12 (250 RMS 1000 W Peak)
--> 4/3/2 Channel Blaupunkt GTA 4 Special Mk II (RMS Power@4 ohms 4x60 / 2x180 watts)
** two chanel of Amp are connected to Woofer and Two Each to Rare Speakers.
Now - My Questions-
I want to go a good speakers in the front ... i am confused between "Component" or "Coaxials"
++ limitation is the in my car the front speaker mounting space is only 4 inches (100 MM) which leaves me with only one choice of "Earthquake" Component systems as only ther are available in 4"
** I am planning to buy additional 4 channel amp (two channels i will use for front component/coaxial and balance two i will use for additional woofer in the rare
so ..please suggest me what should i do ....budget is around 5000 INR (125 USD) for front component / coaxial (apart from amp and woofer)
I would also request you guys to suggest me the good component/coaxial based on your advice which you have to offer...
Thanks...will give millions blessings to you guys
Now - My Questions-
