urgent help SONODYNE SONUS 2605V3 VS JAMO 428
any one heard of DANAVOX POLESTAR VANGUARD VF101
danovox polestar floor standers taiwan based speakers vf101.
they r quoting 70k ??
why they??
you have wharfedale,sonodyne,paradigms....with perhaps zero unsatidfied customers.
for movies you easily go with sonodyne...wont be disappopinted...
where did u get the price for Sonus 26720/=? Can u please give me the dealers contact if in chennai.Thanks in Advance.
I have had the Sonodyne HT setup for the past 6 years. It is really an amazing system for the price it comes at. I have now moved on to Quadral and they too are very good :)
sorry guys ....was busy setting up my HT ...
finally
yamaha 7.1 avr 573
Mordunt short(uk) 10"-175w - sub woofer
Danavox Polestar 101 - FS -200w - left & right
danavox centre
and 2 book shelves.
Epson 8100
grandview 133"
pioneer 450 bdp
573 ... 80W per channel (8 ohms, 20 Hz-20 kHz, 0.09% THD, 2ch driven).
Did you audition the speakers with your AVR ?? Looks grossly under-powered ... as per specs of both. Might not be able to crank up on the volume ... the AVR might go into 'protection' mode!
Our friend Sainath was in a hurry to purchase,apart from our FM'S advices he purchased with many confusions.
no guys was definitely not in hurry..am awaiting mordant short aviano 7 sub woofer 175w...
and about the speakers will tel u the spec
FS specs
fre.resp - 38hz - 20khz +_3db
power.hdlg - 20 - 180w
sensitivity - 90db
impeDance - 4-8ohms
centre specs
fre.resp - 60hz - 20khz +_3db
power.hdlg - 20 - 100w
sensitivity - 89db
impeDance - 4-8ohms
book shel.spec
sensitivity - 89db
impeDance - 4-8ohms
as per the above pls suggest me best AVR
DENON 2113 OR YAMAHA 673 .
or just yahma 573 will do ?
Pls audition the speakers with the avr of your choice and availability before putting in the cash! Detailed, accurate tech specs are never provided by the mid fi manufacturers.
@avidyarthy
bro i ve already purchased it ..its running now.. the dealer is helpful he can replace the avr if i want to...am still awaiting sub woo 175w 10" mordant short.. now i am playing with boston sub used ..i do know how to judge the sound quality ..so if u can help me out ...
What was amount you spend on these Speakers and MS Aviano Sub -Woofer Compared to Sonodyne or Jamo Speaker Packages.:)
