urgent help SONODYNE SONUS 2605V3 VS JAMO 428
@babloo
send me ur mail id .. the dealer asked not to post details on net ..will mail u complete pricelist...also comment help me on the above avr which one is good 573 yamaha is fine or shud i go for 673 yamaha
ok ........ shut off the Boston sub and play the speakers without using the sub. If you like the SQ, then its all fine! Would also suggest playing some bass heavy tracks on loud volume for at least 1 hour continuous. If the avr is on the weaker side, it MIGHT switch off on heavy bass numbers or the speakers could start squealing / clipping. The avr also might get very very hot. That would / could be an indication of it being under-powered, needing replacement with something more powerful.
Subwoofer performance is not avr related .... that has its own source of amplification.
@sainath
send me the details too. I think you can PM me. IF not able to PM, i will PM you my mail id. :)
BTW when i searched the net, there FSs where reviewed as having very good bass. :-)
@babloo
Why not to post the details.Is the Brand Local Manufactured and not to be known to any one about the product?
Anyways it is up to you and the dealer.
BTW if we do not know the proper spects how can anyone recomment matching AVR?
I hope you understand.
Enjoy your new System
Cheers!!!!!!!
FS specs
fre.resp - 38hz - 20khz +_3db
power.hdlg - 20 - 180w
sensitivity - 90db
impeDance - 4-8ohms
centre specs
fre.resp - 60hz - 20khz +_3db
power.hdlg - 20 - 100w
sensitivity - 89db
impeDance - 4-8ohms
book shel.spec
sensitivity - 89db
impeDance - 4-8ohms
ARENT these specs...this is wat was written ..
and the below is wat i got from net
Product Description
- 8.5 driver x 2pcs + 5 driver x1pc + 1ceramic Dome tweeter
- Frequency Response: 35Hz ~ 20kHz 3dB
- Power Handing: 20 ~ 250watts
- Sensitivity: 91dB
- Impedance: 4 ~ 8ohms
- Dimension: 108cm(H) x 25cm(W) x 33.5cm(D)
- Weight: 28.5Kgs (each)
Danavox Polestar Polestar VF-101 Floorstanding Speakers Reviews
i was told not to disclose the price n the net buddy ...thats y not abt the specs...so pls sendme ur mail id .. i will send u the complete price list .. i will be grateful to all the forum members u guys have really helped me alot so pls dont mistake me..
guys no one clarified me ..whether to continue with yam573 avr or upgrade with 673..pls advice....
FS specs
sensitivity - 90db
impeDance - 4-8ohms
centre specs
sensitivity - 89db
impeDance - 4-8ohms
book shel.spec
sensitivity - 89db
impeDance - 4-8ohms
pls advice best speakers
sonodyne or jamo
@ Sainath - I have auditioned both of them. Sonus 2605 is very much balanced for Audio Music and Movie. The sound is very much controlled. Sonus is little lacking a bass effect - which is the only little minus point of Sonus. Whereas Jamo is little bright than Sonus.
If you hear Sonus and Jamo sequentially, I am sure you would like Sonus more....
