USED speakers under - 100 K
Dear friend if you want a set of Quadral Rubin MK II, I can help. See the speccs at the website given below, It is german. If you like, it's ofcource 2nd hand will cost you 35,000/- ex kolkata. I can't deliver it to you. You have to make arrangement.
keep me informed at [email protected]
http://cgi.ebay.de/Quadral-Rubin-MK...ryZ30890QQrdZ1QQcmdZViewItem#ebayphotohosting
Alternativey you can also have the following -
Following tower speaker - 1 pair - new at disposal at Rs.30,000/- ex calcutta.
Please see the product at the below site-
http://www.wharfedale.co.uk/model.php?model_id=20
Specification
Bass 6.5" 2x165mm KEVLAR
Tweeter 25mm silk dome
Power 20-150 wrm
Nominal Impedance 6ohm
Sensitivity 86dB for 2.83v at 1m
Frequency 30-20k
Dimensions 213x900x295
I want to buy a speaker that has a list price of Rs. 2,50,000/-
Used & then selling @ 100/- K or less.
I am looking for a mid-fi product.
I do not want entry-fi.
Thanks for your kind attention and offer. It is appreciated by me.
SHANTI
Hey SHANTI...
please check out the Cadence range....
the Annina speakers well cost about 1.16 lakh....it will be great and awesome....
www.cadenceaudio.com[email protected]
Hi Allwyn !
Thanks for that.
However, the model you suggested is discontinued.
The replacement is a lovely looking speaker. I forget the name. The web site does not have the name or the details either.
http://www.cadenceaudio.com/productfr.html
It has not been updated for the ;ast 4 years.
What I need is a 2.5 Lac list price product @ 100 K second hand.
