Vinyl Cleaning
rcathik
Thoothukudi
Hi Everybody,
I am looking for a cleaning method / solution for my Vinyls. Off late i am getting elevated levels of pops and clicks, read several forms that, it may be because of dust / impurities in the grooves.
I did order a Boundless Audio Record Cleaner Brush - Vinyl Cleaning Carbon Fiber Anti-Static Record Brush , i would like to hear from you on how you are managing to clean your vinyls.
Thanks,
Karthik
There are numerous suggestions and information on this forum sir. There is a video also of the method that Kuruvila Jacob sir is using which I found to be outstanding.
Cleaning vinyl and getting static off a clean vinyl are two different things. I use a spin clean to clean my vinyl. And a audioquest and project static brush before I play the lp. I also use onzow zerodust to clean the stylus. Hope this helps.
Ultrasonic cleaner? Can u be a little more specific as to what brand,etc? Thanks.
Thanks Sir, this definitely helps !
Most of the dirt in a record is inside the grooves. It can only be forced out by a strong vacuum cleaner after the dirt is made loose by some liquid solution. Even the most sophisticated record cleaning machines use this method.
Oh, ok. Will try your method Sir.
Solution -Distilled water + Drops of Enzyme cleaner+drops of surfactant in a 6 lit capacity ultrasonic cleaner.
Ultrasonic cleaning for 5 minutes.
Followed by wet vacuum cleaning.
Excellent results..
Thanks Sir - will check this out.
Ultrasonic cleaner may be a bit out of budget for me - but will try other methods.
Hi Everybody,
Thanks,
Karthik
Vacuuming is the best way.
You can prepare a solution using IsoPropyl Alcohol in Distilled Water in ratio of 1:10. Spray this over the record surface and lot it stay for a while. After that take a soft towel, preferably Micro Fiber Cloth and clean the record in the direction of spinning. This is the cheapest and effective cleaning process
Most of the dirt is inside the grooves and this method may be cheap but may not be the best way to clean the record in my opinion
My Spin Clean is up for Sale. Attaching pics. Do PM if interested.
Thank you
Dr. Pavan
