Any forum members using Onkyo 875?
Need your inputs.
I used to have a Onkyo 503 earlier which was later upgraded to the 875. Volume levels of 20-25 used to be sufficient on the 503 however on the 875 i have to crank it up to 45 or even higher for normal tv(Cable) viewing
I tried the Audessy set up. Did not work well. hence have resorted to manual set up.
What might be the issue here? Is there something amiss here
Also what volume do you generally use while watching 'movies'. Like let say 60% or 70%.
Need your inputs.
