Wattage of the Step Down 220/100v ?
ny2j
gurgaon
Hi Members,
I have to buy a Step down to power my reciever rated 415w and powered subwoofer rated 100w ?
I saw options ranging from 1000w to 2000w.
I will be interested to buy a product that provides vroom to keep my equipment safe. I am not able to decide the right wattage.
415+100=515*1.5 ~ 772w [ as per standard notion to choose power]
Will 1000w suffice for my needs ?
Any specific feature to watch out for in a step down ?
Thanks in advance.
cheers !
i think you are talking about output wattage. what is the input wattage. or the ampere rating on the device. ampere x voltage (in your case 110) will give you wattage. spec the step down about 20% higher than your requirement. i believe 1kw transformer should do. maxine is a good brand and should cost you about 2900 rupees
I got my Subwoofer Polk Audio PSW 505) day before yesterday from USA through Shopyourworld.com. For that I bought a local stepdown 500VA which is working fine. Only thing you have to chech is that output voltage is 110 V which can be done with a multimeter if you have or any electrician can do it for you and it should have a circuit breaker (Fuse) in output line(so that circuit breaks in case of higher voltage). 1000VA step down is fair enough for your requirement and will cost about Rs 1000 - Rs 1500
Manish
I will Hunt for a Step down 1KVA in my region DELHI/NCR and see if i can grab one with auto voltage cut within 1500-2000 range....
i stand corrected on the price. the 1.5kva was about 2900. the 1 kva of maxine was about 2400. you should get other brands within 2000
hi,
I again suggest you to check maximum power consumption of your avr and not rated power..which should not be more than 600w..
~naimesh
Hi, I have an xbox 360 modern warfare edition & oppo bdp 93 both purchased from US. Can somebody please help me how to calculate the step down converter capacity which I would require to run the subject items. Thanks!
max power consumption*1.5 approx
