What cloth for DIY acoustic panel
arunlouie
Bengaluru
I got my new HT installed. Now for acoustic panel I am planning to take DIY route, getting done with Rockwool Silent pro. Now searching for appropriate fabric material to wrap the panels. Also any suggestions to procure in Bengaluru would be great.
You can opt for standard fabrics, but if you're looking to elevate your choices to premium quality, be sure to visit this website. If you have any questions, he is quite knowledgeable and experienced. Additionally, you might want to explore their acoustic panels and other similar products.
You'll get acoustically transparent fabric here:
I bought a pair of bass traps from them recently. Good service, good product. I was going to get the panels made, but after figuring out that I'd have to deal with a Rockwool supplier, get a carpenter to make frames, transport the (itchy and not safe to breath) raw cut rockwool and frame to an upholsterer to finish it, I thought buying ready-made panels more sense to me.
Aural exchange has very goo collection. I have large room to cover, buying ready made will be costly. Thinking of Jute cloth that used for Sofas, the breathable one. The cloth in this site comes around 470 per metre. Will go for that is cheaper.
The "Rockwool Silent pro" are you planning 2in thick or 4inc? : If you got the rough costing options for these and the best sourcing details, could you please share.
I am planning for 4inHx2inWx2in thickness....I think should be fine.... please advise.
