Whcih one to go for ?
dubeyp
Friends help in choosing one of them
Marantz SR4003 $450
Denon 1610 $499
Onkyo - TX-SR 507 - $799
Some more in the range of $750
Denon AVR 1910 $ 799
Onkyo TX-SR607 $ 760
Dubey
ashishkesarwani
New Delhi
Marantz SR4003 $450
Denon 1610 $499
Dubey
Denon1910->Onkyo 607-> Marantz Sr4003->Denon 1610->Onkyo->507.
Choose according to the given order where Denon 1910 comes 1st adn Onkyo 507 Last.
prashant_dv
Depends on what you would be using them for,
Denon is more apt for movies, marantz preferred more for music . It is not that
Onkyo is bad or anything, but have heard it to be a bit bright.
just my 2cents..! If possible, check out these models in your city with the type of music/movies you like.
marsilians
Marantz SR4003 $450
Denon 1610 $499
Dubey
what is your budget? What do you listen to movies vs. music? What speakers do you have?
thevortex
Chennai
If music is very important in your mix of things then the Marantz wins easily here. If it is not that important I would consider the Denon. Also why no Yamaha AVRs? They are excellent.
dubeyp
thanks for the help, I usually listen to music and watch sci-fi movies, I think I will go with Maranz value for money ;) now the tough part come is for Speakers :) I have already 2 diamond Bookshelves from Wharfedale and NAD 320 BEE what should be done bets
ahitdasgupta
MUMBAI
Have a look at the Marantz SR5003 and for speakers, look at the Triangle Galaxy 5.1 speaker system. I have just set it up for a client and he is very happy with the system.
Ahit.
