Which is best from these? Arcam rDAC/Cambridge DACMagic/Beresford Camain TC-7520SE
max123_ind
Hyderabad
Hi guys, I am thinking of asking a relative to get a DAC from UK.
Which is these is best? I intend to use with lot of USB music over laptop.
Please suggest/vote.
Arcam rDAC -- 300 pounds
Cambridge DACMagic -- 235 pounds
Beresford Camain TC-7520SE -- 189 pounds
Also should I also buy an amp or is this enough to pair with bookshelf speakers like QA1010i and use?
Re: Which is best from these? Arcam rDAC/Cambridge DACMagic/Beresford Camain TC-7520S
You forgot emotiva XDA-1 ;)
max, you will either have to use the dac with your onkyo avr or buy a good stereo amp. You cannot drive your speakers, like qa1010i directly using the DAC.
hey Hemant it looks like a PCM 2704 based DAC. Can't be that great.
mbr on the forum has the DACmagic.
psychotropic, blue turtle on this forum had posted his impression on the rdac.
It is older version though,he can tell better.
