Which is BEST?..Oppo 980/981/983 ?
kams
Chennai
I need a suggestion from you guys.It seems Oppo 980 model does not have DTS decoder.It has only Dolby Digital Surround EX decoding.
Will it be a problem for hearing DTS sound track from DVD's?..What should I do to get DTS decoder?..(or) Can I go to Oppo 981 (or) 983?..it also have a drawback..It doesn't have component output.
My AV receiver has everything.Is it enough to hear DTS?
For me Sound is very Important and then picture.I am little bit confused about this..your Suggestions are very welcome..
(P.S: I have posted the similar msg in Cables thread also.)
audiodelic
Hyd/Del
What a/v receiver do you have?
All oppo players will bitstream dts and dolby digital.
Only the 980 can bitstream dsd which is used for SACD.
kams
Chennai
I have Onkyo TX-SR674 Receiver...Bought it on June 2007..
Is Oppo 980 right choice for this receiver?..Because Specification of 981 and 983 says, they will support both DTS and Dolby Digital Surround EX decoding......
But 980 says it is supporting only Dolby Digital Surround EX decoding..
Can you tell me more about DTS decoding of Oppo980?..am I going in the right direction?...
Thanks..
audiodelic
Hyd/Del
Thanks..
Your receiver should decode everything natively all it needs is bitstream. If your budget allows go for the 983h great player, outperforms players costing 4 times as much, unbeatable picture clarity.
Oppo DV-983H Flagship Universal DVD Player Review — Reviews and News from Audioholics
It will do all the existing non hd surround sound formats including the ones you mentioned.
satish
venkatcr
Chennai
As Satish said the best is to allow the AV Receiver to do the sound decoding. Feed the sound from the DVD Player to the AV Receiver through a HMDI or optical fibre cable for movies.
For two channel audio use a simple RCA cable pair and use the Pure Audio option to side step all the video processing. You should get good music across all three models.
Leaving aside the technicalities, here is my take on the three models.
1. The 980 has reasonable video upscaling using Mediatek chips. It has special circuitry for two channel music and has received nods from even Stereophile.
2. The 981 uses the same audio circuitry, but uses DCDi by Faroudja which is supposed to be better in video upscaling compared to the Mediatek chip. It also has DIVX certification though personally I don't see DVDs that have a zillion movies in them.
3. The 983 is the flagship model of Oppo and uses the same excellent audio circuitry of the 980 and 981. For video upscaling it uses VRS? by Anchor Bay Video Processing. This is the currently the state of the art video processor generally used in DVD players costing 2000$ or more. I use a 983, and I can assure you the video output is just superb.
Both the 980 and the 983 perform native Surround Back processing for 7.1 Dolby Digital and Dolby EX processing. The 981 does not do this. But as we said before, if you connect using a optical or HDMI cable, a 7.1 AV Receiver should be able to handle that.
If you are NOT very particular, and allow the AV Receiver to do the sound decoding, you will find little difference unless you are using a TV of 42 inches or more in size.
Best of luck.
abhijitnath
Hi, I have a 980 and it has DTS encoding for sure.
The 980 and 983 have exactly the same audio quality. 981 has a better video chip than the 980, but since I had a 29" SDTV, I doubt the upscaling makes any difference!
The 983 is definitely the best overall, followed by the 980 (for audio) or 981 )for video).
kams
Chennai
Friends ,
Thx a lot for your replies.I am really proud to be a member in this forum.
I am not going to be in India for long time as I am travelling often for onsite.So I am planning to buy 32" LCD TV for time being(for another 6-8 months).As per the Oppo's product comparision.They are strongly suggesting 980H for < 45' screen.Thats why I am thinking about 980H.Budget is not a real constrain for me.I can buy 983H.It is not a problem for me as I am in USA now.
I just want to know the experience of 980H users in terms of picture quality and audio and also want to know if this is perfectly ok for 32" screen.
Please let me know your opinion.
Thanks ,
Pandiyan
square_wave
Edinburgh
Do all these players output DTS and DD as downmixed pcm stereo / two channel through the RCA analogue output ?
This is only a concern for people who watch their movies in two channel stereo.
venkatcr
Chennai
Kams:
Please refer to your last posting. I think I have already answered your question. If you are going with a 32inch TV, the 980 is more than adequate. You will get 1080P Upscaled with a DCDi by Faroudja, and of course excellent two channel music.
square_wave - to answer your question, yes all the players do provide down mixed PCM Stereo for two channel amplification or simply watching through a direct connection to a TV. I am very sure, but I think all DVD players that have multi channel decoding do provide down mixed PCM Stereo. At least my Pioneer's do. In both Pioneer and Oppo you have to set the player for two channel sound.
kams
Chennai
At last I have ordered an Oppo 980H and Monoprice cables..I will receive it in another 5 days..
Venkat,Satish,Abhijit nd other frnds, Thanks a lot for your feedbacks and suggestions..
square_wave
Edinburgh
Kams:
Thanks Venkatcr.
Even my old pioneer dv525 does this. I was just wondering. I am thinking of getting one oppo from the US through a cousin. My movie watching is two channel stereo.
unleash_me
Nostalgia
I see a lot of buzz around Oppo, especially the 983. I can see a lot of enthusiasts (read Satish, Sunil, Venkat...) the fan count is on a steady rise!
Accepting the fact that am not much of a videophile kind - have anyone had a chance to do a comparison with DV7001. I have very little experience with the Oppo range, that also I just heard a few SACDs. I have an ageing 1920 with me now. Saw the Marantz some time back, been thinking about the DV7001 for while now and it just got stronger after a very recent stint! [I can already see the grin on Dinyaar??s face;)]
An inevitable onsite trip is around the corner, don??t think I can escape it this time, so might as well make use of it this way. Any inputs?!
venkatcr
Chennai
Un-Leash Me:
I have not seen the 7001, but for your sake I did a quick comparison of the two players. Here are the main differences:
1. VIDEO: The Marantz uses DCDi by Faroudja for de-interlacing and upscaling. Though this is an excellent option, with the 983, Oppo has gone one step ahead and uses seperate circuitry for de-interlacing and for upscaling. With the DV-983H, OPPO has incorporated Anchor Bay's latest VRS (Video Reference Series) technology. An ABT102 chipset provides AutoCUE-C, Progressive Cadence Detection, and Precision De-interlacing. An ABT1018 chip handles Precision Video Scaling, frame rate conversion, aspect ratio control and video zooming. These technologies combine to generate a clearer, smoother, and true-to-life picture free of artifacts.
In this, simply because of the technology used, the Oppo will be able to provide better video. And this has also been tested to be true. The 983 has been the only DVD player to get 100% in all video tests of Secrets of Home Theater. (Oppo Digital DV-983H DVD Player - Secrets of Home Theater and High Fidelity)
2. CD AUDIO: The Marantz uses Cirrus Logic chipset providing 192MHz/12 bit DAC for audio circuitry. The Oppo uses a Burr Brown providing the same capabilities. Which is better? Difficult to say - CD Players and Amplifiers from companies such as NAD use Burr Brown and are highly respected. Sony, Harmon Kardon, Kenwood, Nokia, Pace and Panasonic amongst others use Cirrus Logic. Marantz's own CD Players use Cirrus Logic and have an undeniable huge fan following. I have myself heard the famous OSD series from Marantz and have lusted after it. I have also heard the Cambridge Audio 640C that uses WM8740 24-bit/192kHz DAC from highly respected manufacturer Wolfson. That also sounds wonderful.
The conclusion? For universal players such as the Oppo 983 and the Marantz 7001 - comparing the audio circuitry (in my opinion) is not too productive. To get really good music, I would stick to a excellent CD Player with a matching two channel amplification. I would play all CDs through that combination.
3. SCAD/HDCD/DVD-A: Here the Marantz uses a 216MHz/12-Bit DAC while the Oppo uses a 108MHz 12-bit DAC. I am not sure what this means as as I have yet to hear any of these CD Types. But spec wise, Marantz may have an advantage.
4. DECODING: The Marantz decodes for 5.1 analogue output, while the Oppo decodes for 7.1 channels. Obviously you get one additional channel (surround back) and will be able to enjoy discs that have Dolby Digital Surround EX encoding.
5. DIGITAL AUDIO. The Marantz boasts a frequency response of 4Hz - 44kHz (DVD fs: 96kHz). The Oppo boasts a frequency response of 20Hz - 20kHz (±1dB). Both have nearly identical THD of >0.0008%. As I have said elsewhere, anything below 20Hz is just specification. The human ears caanot hear it at all.
In conclusion the Marantz may be slightly better for two channel or multi channel audio. But the Oppo is certainly better for video output. As I have mentioned elsewhere I would use a stereo CD Player / Amplifier combination for two channel music, and the specs of the AV Amp for multi channel music.
Am I biased towards the Oppo? I must say I am not. For me the Oppo was the obvious choice for the specs and capabilities it provided for the PRICE.
soundsgreat
Bengaluru
First of all let me just say Am not here to say Marantz is good or Oppo ! I've not seen/heard both hence my absence in this from the beginning !!
I saw few errors and misinterpretations in Venkats post so thought to clarify that !!
The above spec is for the Video not the Audio ! for the Audio default standard for the SACD/DVD-Audio is 192Khz/24 Bit so there will no change in that from any company ! its the Video DAC that some companies use the higher 216Mhz/12 14 Bit and some choose relatively less 108Mhz ! where most of the normal ones use 54Mhz !!
The Dolby Surround Ex Uses Phantom surround channels not actual as the DTS ES which is discrete ! but even otherwise the most probable usage of these players will be with an AVR ! So that already has all the decoding facilities so one should not bother bout these untill and unless they want to use it with old AVR which does not have any decoders onboard !! or use multiple stereos amps for said purpose (which is very very rare)
Agreed without a doubt that below the said frequency one cannot perceive the sound ! but thats not the point !! the point is the bandwidth !! the higher the bandwidth the higher the data packed ! thats the reason why the SACD and DVD-Audio chose the frequency response of 5Hz-100Khz !! its not meant to be for some super humans but for us the normal listeners ! in short if I have to say bout this,Its like compressing and song into MP3,now one can convert it from a decent 128 Kbps to 320 !! now how many will say 128 is good enough we don't need 320 ??? the same way though the Audible frequency is from X to Y but if you have the additional bandwith to pack the data,the data can be packed into a much more detailed manner then the compressed bandwith !! thats also the reason why the difference in the data usage of all these formats !! where a simple 128Kbps MP3 takes about 1 MB per minute and a CD takes about 10 the same SACD or DVD-Audio takes in 10 times more :eek: !! so more headroom and more ambience and more of everything,Hence sounds more natural !
Hope the above point is understood ( everyone ) ;) !!
Regards.
venkatcr
Chennai
SoundsGreat, my apologies for the errors. Here are my two bit for those points:
Regarding SACD/HDCD... my apologies. I forget to mention Video DAC.
Regarding decoding, if you see my post, at the end I have mentioned that decoding and amplification is best left to the AV Amp.
Regarding digital audio, I do agree that more the bandwidth, the more data you can pack. I have nothing against your point.
Even personally, for my IPOD, I compress all my music using lossless AIFF format and don't use the MP3 format at all. I have done this after comparing the compressed format with the original CD format and chosen the one I like best. For my PC connected to the audio system I plan to use FLAC.
At the same time you cannot deny that there are millions of users who are tapping away to MP3.
I have read innumerable debates about this and have seen the results of blind tests. There are various arguments for and against both sides. I just wanted to mention that anything less than 20Hz (or for that matter above 20KHz) is not audible to the human ear. It was just a data point.
kams
Chennai
I have gone thru Marantz website and checked the spec of DV7001 after I saw all your debates..It seems this is also very good player...But Oppo beats Marantz in price.Oppo is $399...Marantz is $799....Oppo is exactly 50% low price compared to Marantz..I think this makes lot of difference from the price point of view..Similar features less price...
Anands123
Hi Kams,
Where did your order the 980 and at what price? Can you also indicate the prices of 981 and 983. Thanks
regards
Anand S
kaushik
venkat ,i agree that the our ears are not good at freq below 20Hz.But bass below 20Hz also adds to the overall experience ....because it can be felt! (probably with outer skin)
Found that info in many places also in magazines like AVMAX/july08...so added here !
venkatcr
Chennai
Anands123 said:
Hi Kams,
Please look up OPPO Digital - Up-Converting DVD Players - Buy Direct from the Manufacturer. You will get all information. In India, get in touch Prithvi of Absolute Phase. The 983H is not available as of now in India, but is expected very soon.
kaushik said:
Venkat, I agree that the our ears are not good at freq below 20Hz. But bass below 20Hz also adds to the overall experience ....because it can be felt! (probably with outer skin)
Found that info in many places also in magazines like AVMAX / July08...so added here !
What you say is true. A lower a sub woofer goes, the better it sounds. So it must be affecting our senses in some way. What I don't like about some sub woofer is the resonance that they create which is completely artificial. A subwoofer sound must be flat and the sound must die immediately.
Some companies are also trying new tricks to increase the sensation. Have you heard of the ButtKicker? (ButtKicker®) It actually physically shakes you in sync with your movies. I am sure people will come up with new ideas. There are some theaters in the US that have chairs that move with the sound and the screen. So if you are watching a flying aircraft, your chair will turn every time the aircraft banks. These are very popular in places such as Universal Studios, and Disneyland where they take a short film, and roll and shake the seats along with the movie.
They also have small shower curtains that throw a fine mist of water on you when the screen displays a waterfall or heavy rainfall.
They are now experimenting with smells, to see how they can dispense a jungle smell or the perfume of a leading actress. Imagine that!!
