Tushaar_14
Hello,
My setup consists of Sony VPL VW550ES, Marantz AV8802A Processor, MM8077 & MM7025 Amplifiers, SA100 Subwoofer Amplifier, OPPO UHD Blu ray player.
Processor was connected to projector through QED HDMI, few days back i switched on the system and played blu ray but no video ouput was there, sound was coming but no display. I thought there is some problem with the projector, i tried accessing settings and they all were displayed and were fine, so i was sure the lamp is fine. Next i hooked a separate hdmi in the other port of projector but still no display, so I took it to the service centre and they said problem is with the hdmi board, next i tried getting a different projector hooked to the processor to make sure nothing else is faulty, but there was still no output, and when i plugged the blu ray directly to projector it worked. So i was sure, processor's hdmi port is gone too, and that QED hdmi got faulty too.
I have an Online UPS installed too, but still this happened, I've been told this happened probably due to power surge, so I should get a Power conditioner.
It would be really helpful if anyone can suggest the best power conditioner for me setup, as the equipments are really expensive and I cannot afford to get these damaged again.
Also what do you think this was due to power surge or something else? Does anybody else has had a similar experience ?
