Which Receiver for Home Theatre?
Pioneer VSX532 or Denon 1200 For Wharfedale DX1
  • Pioneer VSX 531
    Votes: 4 26.7%
  • DENON 1200
    Votes: 11 73.3%
  • Total voters
    15
deep_blues
MUMBAI
Need to buy a new receiver for my home theatre. Using a Panasonic projector, Panasonic blu ray bdp220 & wharfedale dx1 5.1 speaker set up.
Confused between the Pioneer VSX 531 & the Denon 1200.. Have no problem with the difference in budget (Pioneer 29k odd & Denon 42k) but will the denon make any major difference vis a vis the Pioneer with my current 5.1 set up.
Airplay & Atmos not a concern. Primarily sound & video output.
Thanks in advance
Thanks in advance
Not sure if it is still an issue, but earlier Pioneer vsx receivers did not support osd via HDMI; hence confirm if the vsx does support osd via HDMI if the feature is important to you (osd = on screen display)
0.02
Athulan
Better to be future proof and opt for Denon 1200, if budget is not a constrain. Why dont you check Marantz 1506 from hifimart, which comes around the same budget
Marantz is a good choice if you have the budget...else look at Denon which seems to have all features under one roof.
Seen an ad just posted on Hifi ads....Denon 1200
