which velodyne???
For tight & accurate bass get 2 spl 800i (approx 55K each)
or you can aslo go for 2 cht 12(approx 52 each) as suggested by odyssey.
The cht may more apt acc to your set up & taste.
All the best
hey brothers
if i like to purchase velodyne subwoofers which models
price range 50 to 1
Hey Manu - Try Velodyne Impact series. Its 5 star rated sub (as per WHF Mag) and the 12 inch models thats kicks a lot of butt costs only 30k incl taxes.
How difficult and expensive would it be to build a sub?
Can a bridged stereo amp be used to power a sub, or power two subs? I read reviews of some of the amps on audioreview and seems lot of people are using such amps to drive passive subs.
How difficult/ expensive then would it be to build a passive sub?
regards
regards
Generally sub amps are Class-D which offers boost in less spectrum of frequency,whereas ereo amps are Class A+B & gives larger freq response.
Secondly its the internal special circuit which boosts Bass in sub.
In short stereo amp can be used to power a sub ,but SQ output can be below average.:ohyeah:
thanks brothers
for all your rpelies i should lookout for cht series so i can connect 2 15 inches subs in my home theatre :ohyeah:
can someone tell me what is the price of cht 15
Manu Pajji!!!!!
The Cht 15 is arnd 70-75
But b4 you do that what is your room size & rest of the set up again?
All the best
this is a never ending chase. For the same budget, 2 subs MAY give better room response, but in the similar budget you WILL get much better next level sub if you go for single.
Same logic extends for 3 better than 2.
you will be better off using 3 CHT 12s rather than 2 CHT 15s
cheers
Regarding sub-woofers, i wonder if it applies..
to choose 2 or 3 average looking girl-friends
or to choose one stunner.
hmm.......
Its not about getting one better next level sub, perhaps if one goes high enough you will find a single great sub. My point was more about how it integrates into a room, at these frequencies the room plays a very important part and if you want to avoid uneven response at low freq (as much as possible), the best way to do it is to try many subs - all at different positions to each other - as asymmetrical as possible in terms of distances from walls and from each other.
cheers
Manu Pajji!!!!!
All the best
room size 12 feet wide 20 feet long and 10 feet high and also my room is heavily bass trapped :ohyeah:
i have polk tsi 500,polk cs 20,two polk psw 125 subs and four polk tsi 200 for surrounds :cool:
hmm.......
you get easily bored by one stunner girl after a while but if you have average 2 or 4 or 8 girls then every one has their own taste so you never get bored and everyday you have different flavor :cool:
that's what i think :rolleyes:
I hope your wife is not reading this, otherwise your neighbors will sing - tainu dulha kinne banaya .... :lol:
