jatinmalhotra
Hi Sherry
I audioted Minx at FX entertainment CR park
Search forums there is a whole thread for delhi dealers.
What are the costs of these two setups?
Hi TaureanBull,
1. The Violet System has an MRP of 65K (Almost 100K with the Dune HD Max)
2. The other setup would work out to be 130K incl the DHD Max
BTW, are you still in Cairo. I was based out of Zamalek for almost a year and had to come back in Feb. Hope to be back in Cairo soon.
Thanks,
~s~
...You wont get anything out here. :sad:
Hi TaureanBull,
I usually fly in and out via Dubai. Never stopped to check if they had good AV stuff at the DXB Duty Free. Did you?
Thx,
~s~
Dear All,
I visited Lakozy (LN 2) today. Ashish auditioned the Violet system and I have to say I was shocked and then suprised. The sound quality is GREAT. I had almost pulled out my checkbook when we went ahead and decided to audition a traditional (pun intended) HTS.
I heard the Def Tech Pro Cinema 800 running off a NAD (don't remember which model) and was blown away. I got Ashish to play Bryan Adams, Could #9 and the Iron Man scene where Robert Downey Jr.takes out an arms depot in Afghanistan followed by the Raptor chase sequence. Awesome!!
Here's the package that Ashish suggested and I would have finalized had I not heard the Violet. Yes, the sound is so much better from the former but the convinience of the latter makes me reconsider.
Denon 1611
Def Tech Pro Cinema 800 (5.1)
Dune HD Max
I have to give it to Ashish, he was VERY patient putting up with my indecisiveness. I loved his audition room!!!
Verdict: I've never been so confused in my life.
Thanks,
~s~
Hi All,
Can someone advice on my AVR choice? Denon 1611. Can it drive the Def Tech 800 Pro Cinema? Am I future proofed?
Thx,
~s~
Try some avr with preouts like yamaha 667 ... Just in case you want add an amp later to drive some floorstanding speakers as stereo setup.
Update: The Dune HD Max was delivered today. Looks fully loaded from the demo. Don't want to use it with my current equipment. I repacked it and sits proudly with the Tata Sky HD+.
Thx
~s~
Hi Sherry,
What is Dune HD Max? Is it a media player or somethig else? Sorry for my ignorance.
Which speakers could you hear so far? How much separation distance would you be able to provide between the speakers? I think you will do better if you go for a near field monitor kind of speakers...
Welcome to Plasma club
Did you auditioned Minx systems at fx entertainment CR park. they are good too.
@send2sherry : what was the cost of Dune ?
Hi Jatin,
I went for the "HD Max" model. I got it for 33.5K w/o HD.
Thx,
~s~
