32" LCD tv(C530) vs 40" LCD tv (C530)
hbksabhi
Punjab
Guys , thanks to your Help , i have decided to go For SaMSUNG C530 .
I want to know will 40" be more for me or will just suffice !
my room - 10 ft X 15 Ft viewing distance - 6 ft - 8.5ft ( PICTURE of MY ROOM -
USE - XBOX 360 , GAMING AND MOVIES via PC( HD 4890 CARD) , Airtel DTH HD
Like i AM upgrading from 23 "
to 32 " - i will spend 34.5 k
to 40" - i will spend 48-50k
it the increase in price worth it ?
my parents were saying , that our room is not BIG enough ! that i should stick to 32" !
but think 40 " would be perfect ! as i wont buy another in long time !
40 is good for your room . Please search the forum there are tons of threads on the same topic.
Yes dear, kittu1977 is right.
40 inch is right for ur room and yes, there is big difference.:)
i have a 32 inch lcd and my room is slightly bigger than yours 12x16 and frankly it is enough......i was thinking 40 inches but because i also wanted to fit in other things like speakers, dresser etc i opted for 32 inch lcd. In your case why not please your parents and opt for a 32 inch and spend the rest of the amount on something else like a blu ray player etc. Just my advice ....but most people will like a bigger tv.
Someone please tell me .price of series 6 40 inch c630 ?
is it worth it ?
Samsung LA 40C630 was priced @ Rs 64,990 with Reliance DTH free in CROMA PUNE. @ 2yrs extended warranty was Rs 2750.
I am almost fixed on buying this model,but waiting for DIWALI so that the price may go lower. fingers crossed
