3D BluRay Player?
How is Samsung BD - D5500 as an option ?
It supports the most number of formats
It has 3D capability
It does not support 7.1 on DTS because DTS-HD MA is not supported on it. So even if your HT system is 5.1 if you try to play a BD with DTS-HD MA 5.1 you will get the core track output only.
Is Sony BDP-S480 3D Bluray player available in India a "region free" one?
I wanted to buy one, please help.
I believe it will still PASS THROUGH DTS MA if your AVR supports decoding. This way you don't miss anything if your AVR does the decoding (preferred way).
No it is region locked to C.
And prankey yes you are right, that slipped out of my mind, thanks for mentioning this.
Best 3D Bluray player is a HTPC with a bluray drive and a good graphics card (nvidia 400 series and above r equivalent ATI Radeon) and a good software like Power DVD 11 or Arcsoft Total Media Theatre.
Graphics processing power of newer graphics cards are so much more than all available 3d bluray players including OPPO-93 and they give best performance. Even the upscaling prowess is gr8 with the right software like power dvd 11 and they decode all audio and video formats.
madhav is there a possibility of a BD Drive to be region free?
BD drives are all region free and the region locking is based on the software used to play the bluray. Most popular bluray playing softwares are region free :)
Though a few new bluray drives try to lock region, it can be bypassed with a simple firmware patch or crack which is available easily on the internet and takes 5 mins to download and apply :ohyeah:
Haisaikat
India is in region C and Thailand region A, can I be able to use the player bought from there?
Thanks for the info
yes you will still be able to use the player to play region free blu ray players (majority of BDs available in India are region free) as well as Region A (BDs from US if you can get it from there). I would say it will be still way better than buying a region C locked BD Player from India.
Thanks, can i build an HTPC from scratch within 10K with HDMI 1.4 out that can support 3D in future and can bitsream HD audio formats along with 1080p output?
A HTPC is also the most powerful gaming console one can have and also something you will use for work among the countless other things you can do on a PC. So just comparing its cost with a bluray player is not fair and NO you cannot build it in 10k.
Assuming you use your TV as the monitor then atleast 25k-30k+ is required to build a good pc with a powerful graphics card with 3d gaming capabilities.
If I do not require gaming, only 3D playback will I be able to make in 15K? suppose future proof mobo, graphics card, ram and hdd (minimum required), power unit, cabinet, lan/wifi/bluetooth (optional).
Why not a 3d media player? :)
Hmmmm. Probably yes. Get a Core2Duo/dualcore processor and 2GB ram and 250/320gb hdd and Nvidia GT430(costs around3.5k street price) or GT520(around 2.5-3k street price) and a BD Drive(costs around 3.5-4k for lg) and min price power unit, cabinet etc. I think you can get it all at around 15-16k . If you are in Bangalore go to SP Road and you can get it for cheapest prices with warranty/bill.
And this will still have more processing power than even the best 3D bluray player. Use a software like powerdvd11 and nvidia 3dtv play to play all your bluray 3d discs with hdmi 1.4a interface to your tv :) .Not only that, with gt430 or similar gpu you can play most games in 720p 3d atleast with medium settings even though this is not a high end graphics card.
I have such a setup at home and have tried it out for both 3d movie playback and gaming with excellent results and hence i am recommending it.
Thanks. See I like this idea very much. Recently I was researching for importing a 3D BDP from 220-electroinics but seems 3D supported ones will require at least 15K all inclusive so I am wondering if I can get a MADE IN INDIA HTPC in same price no point in going for imported BDP.
How about the following, some lights pls
1. Processor that will be able to pull the load of 3D (SBS) in future
2. Mobo with Remote (must) with expansion options that will be able to support future 3D (SBS as per sam9s) graphics cards, for now 2D GPU
3. 2D GPU with HDMI 1.3 out but should be able to bitstream 7.1 HD audio alongwith 1080p, in future 3D GPU hope will be just GPU upgrade.
4. RAM minimum to support good 2D for now but mobo to support more for future 3D
5. 250GB SATA HDD (5400 is fine over 7200 rpm if the former is cheaper)
6. Zotac (ref suggestion from sam9s from another thread) like slim cabinet that is not vertical.
8. External Blue Ray Writer (USB) / Internal BD Writer (Writer is a must, no point in going for a ROM only option now and later on upgrading) but this must be able to play 3D in future.
9. Wifi Card and Bluetooth Cards are optional and to limit cost can be discarded for now
10. USB + HDMI cable etc are optional and I alrwady have some in stock.
Recently I was researching for importing a region free 3D BDP from 220-electroinics but seems 3D supported ones will require at least 15K all inclusive so I am wondering if I can get a MADE IN INDIA HTPC in same price no point in going for imported BDP when HTPC will be region free as well as said by madhav.
