3d glasses for Epson TW 6100
bikram_singh
dELHI
I was wondering which one of the following two Samsung 3D glasses works fine withe Epson TW 6100 projector?
  1. Samsung 3D TV Glasses SSG-P41002
  2. Full HD Samsung 3D Active Glasses SSG 5100GB
Or is there any other 3D glass i should go for? Please suggest. thanks
Sorry for off track from topic curious to know the performance of 6100 when and how much u had paid it will be a great help.
I am using SSG 5100 and bought it from ebay.in @ Rs 3700 for set of 4. It is very light weight and great to use.
I also will use Samsung SSG-5100GB with My Epson 2030.
If it's not too late I'd go for a wraparound glasses. Those you mentioned will give you reflections on the sides of your eyes.
Get something like these: Amazon.com: 3DTV Corp DLP-LINK 3D Glasses 2 Pairs for ALL 3D Ready DLP Projectors and ALL Samsung and Mitsubishi DLP TV's: Electronics
I tend to dis-agree. Wrap-around glasses are heavy and you if you are wearing them above your spectacles then imagine sitting for 3 hours with them. In a dark room, you really don't need wrap-around so would still recommend to go with simple and light glasses.
I would get both. It also depends where your PJ is. Mine is on a table, so yeah it sucks. I have the first one in the OP's link and they do work great, but the glare on the side...
