One question-
Are those(your)Glasses comfortable on ears?Are they tight to use?
The glasses are quite comfortable. I wore them above my specs and was able to comfortably enjoy the movie. Just ordered another pair of the same glasses.
One question-
Just to add....have stopped watching TV completely...the image appears to be too small
Went home and projected it on a wall which has door and all the knick knacks, every one is wow at home. This one is with zero tweaks to the projector settings.
RBE, I could spot it couple of times in Dark Night, Avatar none, does it bother me? Nope, none at family could ever see that too. Will write a detailed review after setting it up properly.
My colleague is back and my Acer has arrived today, I am waiting to get home and project it on the wall.
It is hand carried by my friend without the carton. The PJ has a carry case of its own. Paid nothing to the customs. First impressions are impressive, for the price of under 30K, it is a value for money projector. Rainbows aren't that bad, but they do exist, this may be because I have lot of metal stuff on the wall like a clock, key hanger etc. You can find the RBE if you look on these objects. My other wall has a mural and it isn't white, so I will be able to post a true review only when I move this to the dedicated room.
I am not able to make the 3D work, I have some side by side MKV files which I played using Panny BDP from a USB, I have 3D Corp glasses, it shows up as side by side in PJ. Any pointers to get this working?
And here is the projected image after working a bit with the settings.
Yes, I did see the solution he posted, but I am playing from BD player. He is playing from a computer. If can't make it to work with BDP, then will try the PC method.
