Active Sub (@ Low Budget)
druk2004
gurgaon
I am looking for a Active subwoofer on Budget which can support the front speakers ....
Need some guidance on the below models:
1. MartinLogan Dynamo 300 Home Theater and Stereo Subwoofer
2. Energy Energy Power 10 Sub 10-Inch Front Firing Rear Ported Subwoofer (Black)
3. Jamo SUB 210 Subwoofer
4. Monoprice 12 Inch 150 Watt Powered Subwoofer, Black
5. Pioneer SW-8MK2 Andrew Jones Designed 100-Watt Powered Subwoofer
6. Polk Audio PSW 121 12-inch Powered Subwoofer
The closest subwoofer would be astonia subwoofer
There are also Yamaha subwoofers but its better if you buy A higher end subwoofer to complement your tsx330 towers. check out Polk audio PSW110. I recently got one for my tsx110b and its a very good one. You should be getting it at around 16k
None of the mentioned models are near 10k except Pioneer that is around 12K
All others are 20K plus
Polk PSW110 is avl for 18500/-
BIC America F12 For 21K
You need to spend upwards of 20K (read 150W RMS Plus) on a sub to complement ur existing Towers or the SW will be of no use
I have got Polk psw110 and its not bad at all. The BIC looks very promising but the budget gets almost double. If the budget is around 20k then many options open up.
