Advice regarding budget RCA interconnect & speaker cable
As for the speaker cable, I will do an incremental upgrade after I listen to the ICs for a month. That will allow my ear to understand how much difference each cable component makes.
Absolutely correct. Best way to judge what each upgrade amounts to.
Just get someone to terminate the IC properly, terminating speaker cables is very easy and u get some good non solderable(crimping) connectors too.
Rgds
Hi Partho,
I personally dont think too much of QED and have never ever bought any. Have heard a few though.
VDH, marbin will courier to u if u want, belden is a good option but i have no clue of chennai availability.
Actually there is no need to just go buy a D102 for 7/8K. Correct way is to get the entry level /The name/The bay etc and listen. Then replace with a D102 and see if u hear a positive difference. I know D102 or similar are good but in some set ups people are happier with cheaper cables.
RGDS
