Bass Traps - Bangalore
Do you know how much are they for and whose selling them?
Joined 10 days back. 11 posts in total. 8+ recommendations for this brand.
I am pretty sure you have no clues. :p
If you could share some more pictures from different angles of the room i would be able to help you some more. I would suggest you check these guys out cueacoustic.in.
If you need any suggestions for people in to this i would suggest these guys cueacoustic.in . I recently got my home theater done from them and also got a great deal on the acoustic bass traps and absorbers.
I would suggest you do a little research before you invest in anything, u can check cueacoustic.in might be able to help your needs.. check it out
Moral of the story make sure what you are buying and from whom you are buying, i would suggest you check them out cueacoustic.in i have their stuff and they are very genuine. They have different ranges from studio acoustics to home theater acoustics and their stuff is aesthetically pleasing.
I gave up on DIY and decided to go with these guys Cue Acoustic India i tested the bass traps that i bought from these guys from cue acoustic and i was very happy with the test results. The cue acoustic bass traps tested absorption from as low as 40hz to as high as 2000hz. Their broad band absorbers tested from frequency 150hz - 20khz.
So for all you having problems with your room acoustic check these guys out or go the DIY way and if you manage to make anything decent please definitely share it on the forum for us to see.
So i would suggest to find a professional in room acoustics who would charge you a bomb or find some one like these guys cueacoustics.in who manufacture ready to use acoustical products or go the DIY way and buy that expensive home theater system and save on the acoustics, the choice is yours.
No wonder so many acoustics related threads are popping up in quick succession.:p
Well i dont know if this particular post is directed to the same site since its an olx ad. Also i can suggest primacoustic, GiK, real traps and so on but you think you will be able to buy them in India? To give you an idea the Primacoustic full trap costs 38,000 INR/- so whats the harm in mentioning a brand that gives the same quality and is less expensive than the foreign products.
Also please note the recommendation is only because im a current user of the same and also i have spent months in researching about the same. Since there aint many manufacturers for products like these, i went ahead and mentioned them.
I have spent a lot of time and money on DIY''s and have ended up spending more than the price of readily available traps and absorbers.
My intention here was to help people and not promote a particular brand. Besides i dont see the harm in helping others.
The spec says that it only handles the mid frequencies.
125 Hz - 0.80
250 Hz - 0.86
500 Hz - 1.26
1000 Hz - 1.16
2000 Hz - 1.08
4000 Hz - 1.10
Do any of you guys got something to share for reducing the window rattling noise !!
I gotta really slower down the rattling noises even @ higher volume level!
Even I am also facing the same problem. I just tried a quick fix solution (more of an experimentation) and it worked, but it may not be the correct solution from sound quality perspective.
I stuffed some old clothes between the glass panel of the window and the window grill and it provided the damping factor.
