Bedroom speakers under 50k
Amitkhanna22
I have a wall mounted 39" Panasonic LED in my bedroom, which is 12'x 15', am looking at wall mounting 2.1 speakers? Need advice on what should be the ideal set up. I have a major space crunch, shall I look at active speakers? A sound bar? Any other idea's, recommendations? My usage is movies, music and news over the weeks ends. I have a Hathway HD box and DVD player directly going to the LED with HDMI.
Hi amitkhanna22
You could possibly consider Boston Acoustics Soundware which are powered...
Boston Acoustics SoundWare XS Digital Cinema Powered Speaker System
Although out of stock with HiFi Mart, you can contact Anil and check when it would be available....Amazon India also has some models on sale....The active bostons I have suggested are good for music, movies and gaming.....Have been using the similar 5.1 speakers with a Marantz AVR more than a year now and the experience is awesome....better than Bose or JBL...you can hear clearly the difference and details...
Soundbars are good to a certain extent....some are standalone without subwoofer and have full range speakers....if you are very particular to what you hear which means you want to hear all frequencies and clarity with punch...the Bostons are indeed true value for money.....
You need to audition a few models and hear the difference yourself....try to demo the same movie or music.....end of the day it all depends on what appeals to you and your budget...all the best
Actives would be better & wise given your space constraints...
You may look @ Sonodyne DAC P1 (Digital Pre-amplifier) + SRP series 201 (Active speakers).... They are wall mountable too.... Approx 55K for this combo...
