Best CD player within 25k NAD/MARANTZ/DENON ???
vikramdesigner
Bangalore/Mumbai
Hey friends,
Looking for a dedicated cd player , my budget is only 25k
NAD/MARANTZ/DENON ? any specific model ?
My currents setup :
KEF Q300
NAD C356BEE DAC
LG DVD Player ( Need to replace this with cd player )
Hey friends,
My currents setup :
KEF Q300
NAD C356BEE DAC
Marantz CD5004
NAD C516BEE
You won't go wrong with any of the above.
Just a curious question - Are you not interested going the PC+DAC way ?
Hey friends,
My currents setup :
KEF Q300
NAD C356BEE DAC
You already have dac in your stereo amp, so you are looking for a better transport or a better dac plus transport?
Right now iam using a Nakamichi MB 2 CDP ....
its very detailed, stores 6 CDs inside itself, however it sounds bright to me cos my speakers are bright too
Tanoj
Maranta 6003 was really good...when i upgraded to 6004 i wasn't all that happy!....6004 can sound a bit bright.....
@robin No
@ Metalmickey
Planned between Marantz cd6005 and NAD c546bee, but i would like to know marantz will be a better choice than NAD ??
Because it all depends on sounding type right now kef is bright and nad amp is warm( sounds good by this combo) , but if i add again nad cdp which is also warm( as its matching cdp to nad c356bee), will it affect the performance or should i go with Marantz cpd as it bit brighter side???
