Best ever deal for loudspeaker kits.
I am in for the X-LS Encore cabinets if its really for $25. Looks like we wont have hassle to have the precision cut with our local carpenter.
Thanks to Capt. Ji for his efforts. :clapping:
@trittya
you have mentioned about different materials for the cabinet. Does the sound get impacted depending on the material.
Dear Joseph,
The three materials I recommended are MDF, marine-grade ply and Baltic/Russian birch. AFAIK, there is NO perceptible sonic advantage (IF ANY) of plywood over MDF.
Some of the world's best speakers are made of MDF but it has to be braced with HARDWOOD. Therefore, sonically they are all at par. Now, structurally speaking, I would prefer ply over MDF for longer/larger/taller cabinets beacuse of two main reasons, one is that structurally, GOOD WELL-BONDED ply is marine grade ply (say, novateak) is superior in the long run as it is much less susceptible to expansion and contraction due to absorption/loss of moisture due to change in climatic/humidity conditions in most of the Indian sub-continent. The third option, Birch Ply would again be overkill for home-equipment. Firstly, its very expensive, about 4 times that of MDF cost and about twice as much as good marine-grade ply and secondly, its not really needed. Pro-audio folks use birch, NOT because of any sonic advantage but because of its durability, as the equipment is bound to get tossed around from venue to venue, one installation after another. Again, NO sonic advantage over the other two.
Sonically, the most exotic ply would be bamboo-ply which is highly weather-resistant, too, albeit not as much as marine-grade ply. The problem lies in getting it in the appropriate thicknes, but if you can, nothing like it.
BTW, one of the largest dealers in bamboo ply in India operates from Chennai. Details here
Marine Plywood,Flexible Plywood,Bamboo Plywood,MR Plywood,India
Here, you should be able to get all that you want and more incl pre-laminated/veneered MDF,HDF or all kinds of ply incl BWP(Boiling water-proof) ply (of course, for speakers that would be OVERKILL)
IMHO a decent(or competent ) carpenter should easily be able to do it,provided the drawings are good. This isnt rocket science.
As Mr. George stated, a competent carpenter can do a good job. Even if he does not have experience in making speaker cabinets, the flat pack can act as a reference for him to make the balance stuff as drawings are already available.
Yes, a competent or decent carpenter can make a good speaker cabinet, but you see, firstly, those two terms are clearly relative and not absolute and secondly, rocket science it may not be, but craftsmanship it surely is. There's another way of looking at it, LOL, there used to tooth-extractions by pavement-based "dental surgeons" before we had dentists touting their BDS/MDS degrees. Different matter that it used to be done with a pair of pliers and NO anesthesia. Though, I seriously doubt whether any roadside dentist could do a ROOT-CANAL-TREATMENT.
On a more serious note, if that gent/craftsman/wood-worker can give you a SONICALLY INERT/DEAD cabinet with proper bracing and sealing, then you are safe. The only point is that a craftsman who has made cabs before is aware of the crucial implications of the finer nuances, so its better, naturally.
I suggest, although I am not part of the build is that, Chennai-ites go to the out-sourced woodworkers of someone like Mr Mark Murugesan of AUDIOCRAFT or Mr John Thankachan of TORVIN, while FMs from B'luru/Hyd'bad can do likewise with those of Mr Siva of CORRSON or Mr Arasu Kumar of LAYA. Mumbaikars/Pune-ites can do likewise with Mr Rajeev D' Souza of LITHOS or Mr Vikram Joshi of RAAGA PROSOUND. Now where does that leave my brethren from Delhi? Well, Woodstock closed down shop long back but there are expert cabinet makers still around in and around Lajpat Rai Mkt as well as the fact that its worth finding out from Mr Nishi Mohan Nakra of ENBEE(since retired) as to where/from whom he used to get his cabs made. FM Parora spoke to him once in NOIDA and may be aware of his contact details.
Methinx it would work out better if the kits are shipped to their respective owners for getting cabs built locally/nearby as per specs/plans. That would save a lot on shipping the finished cabinet, too.
Anyone in North India who cant find a good cabinet maker can get i touch with me and tag along as I am going to get all my cabs for my LINE ARRAYS, Di-poles and down-firing sealed sub-woofer with a 21" driver made from FM Kanwar's woodworking lines. Now, thats an invitation, not a request, lets be clear on that. I, for one, love both mu music and my money and would not throw my hard-earned cash on something that I am not sure about.
At the end of the day, Gentlemen, the bottom-line to all members in this group buy-n-build is that, its your money, your kits and your cabinets. So, the choice, too ought to be yours. The only reason I wrote so much here is that I'd hate to see/know of a FM who is not happy with what he has acquired.
Enough said.
Wishing all of you the very best for the project.
Warm Regards as ever
TRITTYA (the third peg)
Very well said.
@11:00AM third peg. Is everything alright? :D
BTW, I am also with the thought that cabinets could be built locally.Because imagine the weight and cost of shipping compared to cost of actual cabinet.
I caught one guy who will work for me on Sunday evening for 2 hrs max. So I think using 2 Sunday I can get the woodwork done. Sanding and painting (spray)/ some vinyl coating will be my headache. Still it is doable.
Very well said.
:eek::confused:With informer?:rolleyes::licklips:;)
LOL, not that I am on my third peg, thats what/how my user-name is all about/came about,
teen peg pee k poora sach bolne wala
(someone who speaks the whole truth after three drinks).
The surname is a fall-out of the name. After "TRITTYA" one can only be "TUNN", LOL.
It also has a connotation ie its the third peg (spike) that is most crucial to articulation of equipment racks, LOL.
Regards.
Wow Borg, you have truly upped the ante.
OB-7 costs $895 & N3 costs $389
Actually he just needs a single N3S (sealed version) to use as a center channel. So I deduct $20 from the price for no floor spikes and then divide the price by two (since he just needs one of them).
I can also include the shielded woofers for this one by request.
Here is a nice build thread for the N3S: N3S Construction Photos
yup,i am not planning an upgrade for next 5 years minimum, :). for neither 2 channel or H.T
Danny kindly offered me a 15% discount today.so probably able to add the sub too. i will let you know before you close the GB.(need time to research, plan funds)
Hi Danny
Is is advisable to turn that tweeter 90 degrees and mount it vertically for a center speaker configuration or is it better to leave it that way??
TIA
Guys,
Do we know what would be the customs duty on this shipment? Will we be paying the usual 27% over the cost of the product? Do we have the clarity on this aspect? I ask since I need to take this aspect into account if I want to upgrade to something else.
Hi Capt,
Please count me too for the group buy. I need the following
1. A pair of X-LS Encore ($149)
2. A pair of CKD cabinets if the deal work out as mentioned in the thread.
Sethukumar
Guys,
I remember Danny mentioned he can provide individual invoice if payment was made individually. Will this reduce the duty by any chance? Like a group buy shown to customs also :D
Yep, it measured the same if you rotate the tweeter. Keeping it facing vertical (regardless of the way the rest of the speaker is turned) keeps the best and most even off axis response in the horizontal plane.
Hi Danny
TIA
this one looks like 90 deg rotated
GR Research N3S Center Built
Yep, and it looks good doesn't it. Ruben does a nice job with the cabinets that he builds for my custmers. I'll try to repost that pic here...
I dont know how this is going to pan out. If they see 2-3 sets for the same person, the customs will charge the duty. I dont see how to we can get around this. I am assuming that worst case, we should keep 27% or whatever as custom duty that will be charged.
Hope knowledgeable FMs can give some info here. I know someone who has retired from Customs. Will check with him. Do post all your queries so that I don't bug him with queries daily.:D
http://www.hifivision.com/general-lounge/7703-custom-tariff-calculations.html
in this suri says he paid 13% for the drivers from madisound
whether we get any reduction because these are not finished goods
Any speaker manufacturer willing to import these for us?:D.
In my previous company (which is located in an EHTP), i was told that no need to pay duty for any component they import which is used for manufacturing.
@Danny
can your contact at peerless help?, any savings in customs duty will be translated to more orders for you:D:D
@Danny
can your contact at peerless help, any savings in customs duty will be translated to more orders for you:D:D
I have always paid duty on my digikey shipments(resisters,capacitors etc).
Sachin
I would like to take on X-LS Encore Stereo speaker pair kit @ 149. Please add me to the list
I am also interested in the cabinet to be locally sourced. I understand that is not yet decided. But will be interested.
I am from Bangalore
Philip.
LATEST UPDATED LIST FOR DISCOUNTED DEALS FOR GROUP BUY ON FIRST COME FIRST SERVE BASIS IN CHRONOLOGICAL ORDER
Confirmed members for X-LS Encore Stereo speaker pair kit @ $149
Capt. Rajesh - Chennai
Stereorules - Hyderabad
Arunlouie - Chennai
Omishra - Pune
Baswamin - Bangalore (2 pairs)
Novice-akki - Delhi
Josephjohnt -Bangalore
Sbg - Bangalore
Sachu888 - Nashik
Anil Kumar - Bangalore
Odyssey - Bangalore
Madurai1974 - Mumbai
Rgn1 - Bangalore
Total 14 pairs
Sonicap upgrade for X-LS Encore(Best bang for the buck)@ $72.40
Capt. Rajesh
Omishra - Pune
Arunlouie - Chennai
Total 3 kits
The full monty upgrade for X-LS Encore @ $161.8 (Look here for details)
None
Confirmed members for cabinets in black finish from Danny for X-LS Original/Encore in black finish @ $125
None
Confirmed members for Encore X-CS Centre speaker kit @ $99
Captrajesh Chennai
Josephjohnt - Bangalore
Total 4 Nos
Sonicap upgrade for Encore X-CS Centre speaker kit @ $67.15
Captrajesh - Chennai
Total 1 kit
Confirmed members for A/V 1RS surround speaker pair kit @ $194.65
Total 5 pairs
Confirmed members for Subwoofer kit GR SW-12B + SA-1 Sub amp
Captrajesh - Chennai (One SA1 with two SW-12B drivers)
Baswamin - Bangalore (SW-12B driver only)
Hemant.hg - Bangalore
Total SW12B drivers 6 Nos
Total SA-1 amps 4 Nos
Confirmed member for X-Static kit
Odyssey - Bangalore
Total 1 kit
ITEMS IN THE HOT DEAL THAT ARE STILL AVAILABLE
X-LS Original / Encore kits @ $109 / $149 - Plenty
X-CS Original / Encore kits @ $79 / $99 - Plenty
SA-1 Subwoofer amp @ $199 - 2 Nos
NO DISCOUNT ON THESE BUT INCLUDED IN THE GROUP BUY TO ENABLE CHEAPER SHIPPING
Confirmed member for Subwoofer kit Dual GR SW-12-08 + Rythmik A370PEQ Servo Sub amp listed @ $667
Anm - Delhi
Total 1 kit
Confirmed member for Subwoofer kit GR SW-12-04 + Rythmik A370PEQ Servo Sub amp listed @ $ 498
Total 1 kit
Confirmed members for No Rez lining listed @ $39.95
Borg - 3 sheets
Rgn1 - 2 sheets
Total 5 sheets
Members sitting on the fence
1. Vinny_Wills - Encore pair
2. Jls001 - Encore pair + Servo Sub kit
Confirmed members for Original X-LS Stereo speaker pair kit @ $109
None
Confirmed members for Original X-CS centre speaker kit @ $79
None
KITS FULLY BOOKED AND NOT AVAILABLE WITH DANNY
1. Subwoofer kit Dual GR SW-12-08 + Rythmik A370PEQ Servo Sub amp
2. Subwoofer kit GR SW-12B + SA-1 Sub amp
KITS (BOTH PART OF ORIGINAL GROUP BUY AND THOSE NOT A PART OF BUT CLUBBED TOGETHER TO ENABLE CHEAPER SHIPPING) STILL AVAILABLE AND GROUP BUY IS OPEN UP TO 30.09.2011
1. Original X-LS Stereo pair kit
2. Original X-CS centre speaker kit
3. X-LS Encore Stereo pair kit
4. X-CS Encore centre speaker kit
5. A/V 1RS surround speaker pair kit
6. X-Static Stereo pair kit
7. Any other product from GR Research subject to Danny's willingness to club with the consignment.
GO THROUGH THE THREAD ON AUDIOCIRCLE WHOSE LINK I'VE GIVEN IN THE 1ST POST FOR SOME MORE KITS I.E. X-OMNI FOR FRONT & SURROUND AND X-VOCE FOR CENTRE CHANNEL
