bluray payer with front panel display
amateur
chennai
I have Sony bdp s1100. I have a old Denon 1306 avr , I have connected Klipsch speakers via coax - I want to use it only for music - no TV/Monitor connected now.
Now the question is the player doesn't have display in the front panel, hence I am unable to switch between USB and CD.
is there a blu ray player that has front panel display that shows the source and the ways to toggle between USB and CD using remote ?
is there a way to do this switching in my current blu ray player itself without connecting it to external monitor/TV.
Most of the competitive brands have display and it is possible to some extent to play without a display.....depending on your budget, you can possibly see some suitable models and purchase the same....
thank you for the reply, Sony one that I have doesn't have.
Samsung - from the net, if I see, I couldn't find any display there.
could see the display in Pioneer BDP 160 model.
thanks for the reply - not sure if I can toggle between USB and CD with selection of folders, etc in usb, anyway , let me check once again.
