0verkilled
I know there are lot of questions like these already, but I need your help in choosing this one. I will keep it as focused as possible. I have read a few forums and finally zeroed in on 2 DACs: JDS Labs ODAC and HRT Streamer
I currently have MS Avaiano6 and MH 25.2, currently using my Bluray player as DAC/streamer from PC.
I want to play music directly from PC and hence need a USB DAC, I am planning to put this DAC inside the PC cabinet and if its USB only DAC there is no external power supply, saving me by one extra switch to turn on.
From the reviews I learned that both are a little bright sounding and I am ok with it, considering my amp and speakers are very laid back, this should be fine. However, I dont know which one to buy.
Schiit Modi is also in my budget, and weiliang's dac that our fellow fm recently bought although a bit pricey- New Finished AK4495SEQ AK4495 AK4118 DAC Decode LM49860 High Quality Audio | eBay, problem with this dac is the quality issues that might come up later, some people complaining about loud sound being heard whenever its switched off or on.
Both these DAC's would be difficult to fit inside the PC cabinet.
Your help is very valuable to me. Thanks in advance.
