ashwinurao
Sorry if this issue has been beaten to death here, but I have one basic question. I did read the numerous threads on PAL, NTSC and have understood quite a lot.
I got Sony Bravia EX700 TV from US which has only NTSC tuner.
Right now I am using an external TV tuner and feeding it composite in from tata sky and taking VGA output to my TV which has VGA input. Ideally I should use a PAL->NTSC convertor like this one - PAL to NTSC Video Converter | PAL to NTSC Video Conversion | Pal Video converter | pal to ntsc TV converter | convert ntsc to pal | convert pal to ntsc | Pal TV converter .
Now I am planning to get a HTiB and was wondering :
At the SD level PAL is 50Hz and NTSC is 60Hz. So in US the TV signals are 480/60i and here it is 576/50i. So we need these convertors to convert these signals to the proper refresh rate and resolution.
Now if I connect my TataSky composite output signal which is 576/50i to any AVR with video upscaling feature it should ideally upscale this to 1080/60p. Now the output from AVR will go to my LED TV through HDMI. Since my TV supports 1080/60p it should ideally display this without any issues, right? So, does this mean that I dont need an intermediate PAL->NTSC convertor equipment(or the TV tuner)?
