Cannot access audio through arc port.
Himank Dodeja
SITAPUR
Hey,
Can anyone tell me how to set output of my IFFALCON V2A smart TV to MY SPEAKERS (SONY HT-S20R) through HDMI. I cannot connect it using hdmi cable. Rest other sources are working fine.
You mean you can't get output using HDMI or you do not have the option to use HDMI?
If it is the prior, try changing the port from ARC/eARC to HDCP 2.2 or vice-versa, sometimes that is all that is required!
