Car components.
Musical Assassin
India
Hey guy's I'm looking for a advice regarding upgrade of music system in my 2020 Mahindra thar.
Soo I'm looking for components which are more focused towards producing clear sound rather than bass.
My budget is in between 10k-15k.
I have seen lots of positive reviews for JL-audio c1-650.
Which components do you guy's suggest?
I think it would be great if the FMs mention the model numbers too instead of generalizing..It would help the OP as well as future buyers as a reference. Cheers.
I am looking for sound upgrade for my xuv 300,
Budget 10k to 15k
Boot space essential
Sound should be like I can differenciate instruments,clear with good bass
I am using focal components which I got in that budget and they are very clear,punchy and produce well separated sound. I am using them through a rainbow amplifier.
Are they suitable for XUV 300? Door damping required for the same?
