hemant0285
Hii.
I have an old Sony CD Walkman , D-EJ855
1.It uses the following batteries- Sony NC-6WM
The batteries have leaked , so I need new batteries. but not able to find dem.
Where can I possible find these batteries.
2. It has an Optical out
and the manual says
Optical Digital Output
Output Level: -21 --- -15 dBm
Wavelength: 630-690 nm at peak level
I did nt understand a bit of wat these specs mean. I was wondering if its going to be of any use for connecting to an AVR with digital output..
So tat it can be used in place of buying a new CD player..
3. Which type of Optical output cable is it gonna use.?
Below pic is from d manual.
hemant
and the manual says
hemant
