Ceiling Fan
raghumailbox
Hi Friends,
This post is related to ceiling fan for home.
My existing regular ceiling fan with 3 blades in my living area gives the cool air only under it and not at the corner of the room.
Can someone suggest about buying a ceiling fan which can give better air around the room?
Why not buy a wall fan? They can be made to rotate so that air gets moved around to all corners. You get them with remote control also so that you don't need to keep getting up to adjust it.
Wall fans would be noisier if that is a concern.
What is the room size? You could go with a larger fan, a fan with four blades or two fans.
Look for 1400 mm throw fans. They will provide an airflow around 290 m3/min. That would be 15% to 20% above the 1200 mm throw fans. Ortem is supposed to have the highest air flow and also the highest power consumption.
Also look at Super Fans and Orbit Greens which have 1400 mm versions that consume less than 40W, almost half of regular fans
Tower fans like ortem is the only solution for covering all areas and it can also be moved around as and where required. It is also noiseless and air throw would be cool comparing to a ceiling fan.
