centre speaker
abhirag
BSR
Kindly suggest me which centre and surround speakers and sub woofer I should go for.My present set up is
Yamaha rxv 800 av receiver
rotel rb 985 power amp
Front Speakers-Woodstock 5way 12"driver \
Centre -JBL centre MR
Surround-DIY kind not proper
At present I am not using any subwoofer but I think I should buy one.I want to replace my centre and surround.My budget is btwn 25-30k.
why dont you go with the same as your woodstock speaker - not sure what price point they're at though
Abhirag
The normal recommendation is to use the same brand of driver/speaker when you have a 5.1.You can use any brand of sub, though.
George
