Coco Leni Frames
moktan
Kalimpong
I’m looking for general feedback from Coco Leni owners on build quality and materials.
How would you rate the acetate/metal quality, hinges, and overall finish in daily use? Do the frames hold alignment and adjustment over time? Overall, do they feel well-constructed and durable, or more fashion-oriented?
Perhaps they are India’s answer to Akoni , Jacques Marie Mage etc 😀.
I have one from Cocoleni, the material is fantastic, build quality is great and they will last you forever, and the other frames that i have used are from lenskart and rayban from Titan eye, the difference between cocoleni and these are the comfort of wearing them all day, cocoleni has no spring loaded frames ( at least not the one i have) so they are not comfortable to wear all day, plus they are a bit heavy so factor that in, cocoleni is more of a statement which you can wear once in a while but use the lighter more comfy frames for regular use
