Cracked - How to configure Harmony 525 to Tata Sky +
Why
delhi
Follow the following simple steps:
- For Devices to add select "Video Recorder ----> PVR"
- For Manufacturer select "Tata Sky"
- For Model type in TATA SKY+ (as prompted)
Hope the above helps!!
yup, but a few keys don't get assigned, for me the forward key didn't get assigned, and i think the 'plan' key or the 'guide' key, i had to manually customise it. worth keepinig in mind.
I think the 525 states it cannot handle DVR/PVR so you need to go for a higher model for default recording options as there are no specified buttons for the same.
there is a specific record button that can be programmed to match the 'record' key on your PVR remote.
But generally I've been finding the 525 a bit of a pain to use and find myself reverting to using the individual remotes.
