Definitive Tech Procinema 5.1/7.1/9.2
starkind
India
Hi there,
I need review on the below configuration & help me select the best.
Room Size: 16x25 (feet)
Option 1 (5.1ch on-wall system)
Def Tech Pro Cinema 1000+
Maranta SR5010 AVR
Marantz Blueray Player
Option 2 (7.1ch on-wall system)
Def Tech Pro Monitor 1000 (2ch)
Marantz SR5010 AVR
Option 3 (9.2ch on-wall system)
Def Tech Pro Monitor 1000 (4ch)
Def Tech Pro Sub 1000
Marantz SR6010 AVR
I am looking to buy only from the Definitive range & selected the ProCimena/ProMonitor as i am tight on budget.
Looking forward to your inputs.
Definitive Tech + Marantz pair well, you need to decide based on your budget what appeals to you......take your music or movies and check the effects...
The 5010 has 100w RMS raw power at 8 ohms load and 140w @ 6 ohms...there is enough to run speakers even which are rated 120-150w........
All the best....
Any specific reasons for DefTech only?
I found the pro cinema series great for movies but not so good for music.
I would suggest you look at NHT also.
@starkind
SR5010 and SR6010 are 7.2
For 9.2 you need to go for Marantz 7xxx series.
Where are you sourcing the avr/speakers from, India or abroad?
Raghu
