DIY 2 Way for HT \ Music
balaji.jkb
United States
Dear All,
I wish to build a DIY 2 way speaker.
Prefer to use them for Front Left&Right speakers for Harman Kardon AVR
Wish to have natural sound with essential bass,
Found this Dayton Amiga diy with in my budget.
https://sites.google.com/site/undefinition/diy/amiga
Please share your suggestion and ideas for other diy kits and raw driver
It shouldn't be earth shattering bass kind of SPL output.
Peerless and Dayton are the affordable drivers..
Since its a two way design zoo most of midranges (apart from the low end) will also come from the woofer alone. A rear end will help a lot. A front end will muddle the mid range part.
If you are going for it, please keep us updated.
My initial projects were all two way bass reflex systems and they sounded just great, using Alinco philips woofers and tweeters with real large magnets.
Best of luck.
I dont think so many hi end speakers are using front end port that will not do anything with midrange that will help to keep the speaker somewhat close to walls.It will depend on the cabinet construction.For small room always better front port design
Thanks Folks for your suggestions..
Sure will update you on DIY progress and it will be a little slow process to source the product via friend who is coming from onshore.
pardon me for asking a noob question. i couldnt find the Private message link in the site. do we have some thing like that to send a private note for a user :-)
hi check diyaudiocart website you will get his contact number I think becuse of a new member that option is not available you have to post minimum number in forum to enable private message option
