Audio_Freek
I think there are some clearly established rules -
1 - Bigger driver can give more SPL and is essential for LF
2 - More number of drivers means more independent and truthful sound generation generally(as there is lesser distortion, because of dedicated driver for each frequency range).
3 - Cabinet, driver material, crossover material does affect the sound quality. At least it would affect the durability.
For systems below 30k, you will be missing at least first 2 points mentioned above. You wont be getting true LF, would not get multiple(3 or more) good drivers.
50-60k seems to be the real saturation point.
Headphones and IEM can achieve this same level of SQ at much lesser cos, but they have their own limitations.
theredcommando,
With your point of view, the FS should be the best as its atleast covers point 1&2,but in real case scenario rate and performance of BS and FS doesn't have much difference.
Sorry to talk apart form title, In my childhood days i use to think like "The speakers with very heavy magnet,Dust cover and size are the best in world" but once coming to the real world understood the Quality..
The Speakers played in local orchestra will be big,with many drivers but if you look the quality of sound, it will be thrown out.
About 3 - Cabinet, driver material, crossover material does affect the sound quality. At least it would affect the durability.
I have read an article that B&W is spending much on designing its new cabinet to give a different look on its speakers apart form rectangular box
I have noticed the Paper-cone drivers delivers the voice and strings accurately than fiber cone drivers
Cross-overs are some great stuffs and i cant consider it as misc material placed in speaker.. If you play any BF or FS directly from output, without connecting to the CROSS-OVER ,Am pretty sure your tweeter would just while increasing the volume.
The reasons i could list out these things is" Am not a DIY party, just i have experience in re-coning my own speakers to a large extent and finally gave up understanding the about things.
A GOOD SPEAKER NEEDS
Good cabinet designed with proper material measuring the total drivers performance.
Quality drivers build with proper material and coil etc
Good Cross-covers which does the job of distributing the frequencies for the drivers
